[OpenLayers-Dev] duplicate attribution
Tim Schaub tschaub at opengeo.org
Thu Oct 8 12:32:58 EDT 2009
Christopher Schmidt wrote:
> On Thu, Oct 08, 2009 at 10:06:25AM -0600, Tim Schaub wrote:
>> Hey-
>> Marc Jansen wrote:
>>> Hi Tim,
>>> thanks for the review. Renaming seems reasonable, I guess there is no
>>> wrong or right.
>>> As for the default: I chose not to break the behaviour of the control
>>> when being called without the parameter "eliminateDuplicates" set. On
>>> the other hand: I can hardly guess of any situation where you wanted
>>> duplicate atttribution texts.
>> Yeah, I would suggest that it is a bug to show the same attribution
>> twice.  In that light, changing the behavior would be fixing something
>> instead of breaking something.
>> Anybody else think that displaying the same attribution text multiple
>> times makes sense?
>> I'm guessing there is not a strong opinion one way or another.  I do
>> like the idea that at some point we can streamline the API, instead of
>> continually adding to it (particularly in cases where we are adding
>> things to work around somewhat odd behavior).
> REviewed it, though honestly, I'd be willing to drop the option, since it
> seems silly to maintain buggy behavior, and I can't imagine a case where
> this behavior makes sense.
Cool.  I agree.
http://trac.openlayers.org/attachment/ticket/2300/2300.2.patch
Tim
> -- Chris
>> http://trac.openlayers.org/ticket/2300
>> Tim
>>> Just my two cents,
>>> Regards,
>>> Marc
>>> Tim Schaub schrieb:
>>>> Thanks for the excellent contribution Marc.
>>>> http://trac.openlayers.org/changeset/9720
>>>> I think it would be worth making eliminateDuplicates true by default
>>>> (and maybe changing it to simply "duplicates" and making it false).
>>>> Would anyone object?
>>>> Tim
>>>> Marc Jansen wrote:
>>>>> Hi Bart,
>>>>> thanks for the warm welcome :-)
>>>>> Bart van den Eijnden (OSGIS) schrieb:
>>>>>> Hi Marc,
>>>>>> welcome to the community, you're almost there (opening a ticket with
>>>>>> a patch is the right way), a few pointers:
>>>>>> -it is wise to set the state of your ticket to review, also if you
>>>>>> want it to get attention, make sure the milestone is the next
>>>>>> possible release (right now 2.9)
>>>>> OK. I'll change that
>>>>>> -a patch with a testcase is better than a patch without a testcase,
>>>>>> so if you could look into how to write a testcase that would be great
>>>>> OK. I will try to do that as well.
>>>>>> -a patch should ideally work against trunk
>>>>> Both patches work against the latest version of the trunk... or am I
>>>>> misinterpreing something,
>>>>> Regards,
>>>>> Marc
>>>>>> Best regards,
>>>>>> Bart
>>>>>> Marc Jansen wrote:
>>>>>>> Hi devs,
>>>>>>> I recently opened two tickets ([1], [2]) for new / enhanced
>>>>>>> functionality of OpenLayers components. Both of them have (more or
>>>>>>> less trivial) patches attached to provide the actual functionality.
>>>>>>> I would love to have a short note/review about the code in question
>>>>>>> by someone with deeper insights in the project.
>>>>>>> I am not quite sure if I did everything the "OpenLayers-Way". Is
>>>>>>> the process of opening a ticket and submitting a patch the desired
>>>>>>> way? Should I have started a discussion on this list prior to
>>>>>>> opening the ticket? Please help me since I would love to
>>>>>>> participate in the project.
>>>>>>> BTW: I have not handed in a CLA up until now. Maybe we can fix this
>>>>>>> in Sydney, as I guess many from the project will meet up there.
>>>>>>> Regards,
>>>>>>> Marc
>>>>>>> [1] http://trac.openlayers.org/ticket/2266
>>>>>>> [2] http://trac.openlayers.org/ticket/2288
>>>>>>> _______________________________________________
>>>>>>> Dev mailing list
>>>>>>> Dev at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>> Dev mailing list
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
Tim Schaub
More information about the Dev mailing list
