[OpenLayers-Dev] bbox=Nan,null,null,null
pericoltoxic
grigoregeorge631980 at yahoo.co.uk
Fri Oct 16 02:58:13 EDT 2009
Christopher Schmidt-2 wrote:
> On Thu, Oct 15, 2009 at 06:26:49AM -0700, pericoltoxic wrote:
>> Hello!!! Sorry for my English, I'm new in OpenLayer and I have a problem
>> to
>> render(view) a map.
>> This is my html page:
>> <html>
>> <head>
>> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
>> <title>Untitled Document</title>
>> <script src="http://openlayers.org/api/OpenLayers.js"></script>
>> </head>
>> <body>
>> <div style="width:100%; height:100%" id="map"></div>
>> <script defer="defer" type="text/javascript">
>> var map = new OpenLayers.Map('map');
>> var wms = new OpenLayers.Layer.WMS("gtest2",
>> "http://localhost:8080/geoserver/wms",{
>> srs:'EPSG:2000',
>> styles:'',
>> format:"application/openlayers",
>> layers: 'cite:gtest2',
>> map.addLayer(wms);
>> map.zoomToMaxExtent();
>> alert(wms.getURL(new OpenLayers.Bounds(map)));
>> </script>
>> </body>
>> </html>
>> When i run this code, i have:
>> http://n2.nabble.com/file/n3829292/error.jpg
> Why are you calling wms.getURL? You shouldn't need to do that.
> http://trac.openlayers.org/wiki/TroubleshootingTips#Pinktiles
>> View this message in context:
>> http://n2.nabble.com/bbox-Nan-null-null-null-tp3829292p3829292.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Christopher Schmidt
> MetaCarta
> Dev mailing list
I use this function:wms.getURL...... because i wanted to see the URL. I
copied the URL return from this function( wms.getURL) in the browser to see
the result.......the result is a xml file. The content form the xml file is:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://localhost:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" >
<ServiceException>
java.lang.IllegalArgumentException: Bounding box coordinate 1 is not
parsable:null
Bounding box coordinate 1 is not parsable:null
</ServiceException>
</ServiceExceptionReport>
View this message in context: http://n2.nabble.com/bbox-Nan-null-null-null-tp3829292p3833969.html
More information about the Dev
