[OpenLayers-Dev] bbox=Nan,null,null,null
Christopher Schmidt crschmidt at metacarta.com
Fri Oct 16 08:57:42 EDT 2009
On Fri, Oct 16, 2009 at 05:13:26AM -0700, ralthaus wrote:
> pericoltoxic wrote:
> >     <script defer="defer" type="text/javascript">
> > 	var bounds=new OpenLayers.Bounds(-180, -90, 180, 90);
> >     var map = new OpenLayers.Map( 'map', {maxExtent: bounds,
> > projection:"EPSG:2000"});
> > 		//var map = new OpenLayers.Map('map');
> > 		var wms = new OpenLayers.Layer.WMS("cite:gtest2",
> > 			"http://localhost:8080/geoserver/wms",{
> > 			styles:'',
> > 			format:"application/openlayers",
> > 			layers: 'cite:gtest2'});
> > 		map.addLayer(wms);
> > 		map.zoomToMaxExtent();
> > 		alert(wms.getURL(new OpenLayers.Bounds(map)));
> > 	</script>
> Hmmm, when you make "wms.getURL(new OpenLayers.Bounds(map))", you make a
> double strange thing : you create "new" bounds (you don't want new bounds,
> you want to get your map's bounds) , and arguments for OpenLayers.Bounds
> are...bounds, not a map
> To get your map bounds, you should make something like
> wms.getURL(map.getExtents())
   getExtent(), not getExtents().
> View this message in context: http://n2.nabble.com/bbox-Nan-null-null-null-tp3829292p3835209.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
