[OpenLayers-Dev] Vector feat. from WKT fucked up in IE but fine in
Firefox, and Chrome
hauxon
hrannar at loftmyndir.is
Thu Oct 22 07:52:52 EDT 2009
I'm doing a map where I draw a feature by using the DrawFeature control and
then store it in a DB as WKT. Then I'm calling the feature back by quering
the DB and parsing the WKT string to a feature. Works correctly with
Firefox and Chrome but the vector renders shifted few meters and rotated in
Internet Explorer (both IE7 and IE8). I does not matter if in witch browser
I draw the feature, the WKT saves correctly and the same way from IE and
Firefox. But when rendering the feature back IE gets it wrong. I have
projection suspected but can't find anything wrong, the map has EPSG:3057.
I do harvest the bounds from the feature after reading it from WKT and all
browsers zoom in and set center correctly.
Here's an image to illustrate the problem:
http://farm3.static.flickr.com/2470/4034630696_b41e6b3b9c_o.jpg
Here's how I'm reading and inserting the feature:
//Create an array of features from WKT
var wkt = new OpenLayers.Format.WKT();
arr = new Array(wkt.read(xmlHttp.responseText));
// Create a vector feature from wktArray (only one element for LINESTRING
used here)
var feat = new OpenLayers.Feature.Vector();
feat = wkt.read(xmlHttp.responseText);//arr[0];
// Add feature to Drawings layer
getLayerByName("Drawings").addFeatures([feat]);
// Lets zoom down to the feature
var drawingBounds = new OpenLayers.Bounds();
drawingBounds = feat.geometry.getBounds();
map.zoomToExtent(drawingBounds);
map.setCenter(drawingBounds);
Thanks!
Hrannar Hauksson
View this message in context: http://n2.nabble.com/Vector-feat-from-WKT-fucked-up-in-IE-but-fine-in-Firefox-and-Chrome-tp3871781p3871781.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20091022/6fa8c2df/attachment.html
More information about the Dev
