[OpenLayers-Dev] Removing Info bubbles
Ringdahl Niklas
Niklas.Ringdahl at sweco.se
Fri Oct 23 04:09:57 EDT 2009
If you are using the addPopup method of the OpenLayers.Map object, you can specify this in the function call. Then OpenLayers will handle this automagically.
addPopup
addPopup: function( popup,
exclusive )
Parameters
popup {OpenLayers.Popup<http://dev.openlayers.org/docs/files/OpenLayers/Popup-js.html#OpenLayers.Popup>}
exclusive {Boolean} If true, closes all other popups first
http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html#OpenLayers.Map.addPopup
- Niklas
Från: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] För subash_ks
Skickat: den 20 oktober 2009 09:09
Till: dev at openlayers.org
Ämne: [OpenLayers-Dev] Removing Info bubbles
Hi All, I have an openlayer map with several markers.By clicking on the markers its showing info bubbles.But i need only one info bubble at a time.That means by clicking on the info bubble i have to remove older info bubbles,i need only the newely clicked one.Is it possible ?I am using mapstraction library also. Thanks and Regards, Subash K S
View this message in context: Removing Info bubbles<http://n2.nabble.com/Removing-Info-bubbles-tp3857118p3857118.html>
Sent from the OpenLayers Dev mailing list archive<http://n2.nabble.com/OpenLayers-Dev-f1832264.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20091023/2e9411b1/attachment.html
More information about the Dev
