[OpenLayers-Dev] Thoughts about #2318: move pink tiles to css
Zac Spitzer zac.spitzer at gmail.com
Sun Oct 25 23:15:04 EDT 2009
something like a layer option of cssErrorClass ?
i have been pondering the idea of a different debug behavior
for uncombined library usage..
z
On Mon, Oct 26, 2009 at 1:18 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Roald de Wit wrote:
>> Hi list,
>> During the FOSS4G 2009 codesprint I worked on ticket #2318 [1], which
>> has been committed to trunk. It is now possible to fully control the
>> looks of a broken image using CSS. The change also involves setting the
>> src of the broken image to a blank.gif.  There is one drawback with this
>> last addition: you cannot right-click on the image anymore to see a
>> possible server error (since the src URL has changed).
>> Is this behaviour something we can live with or would it be better to
>> keep the src URL pointing to the original image?
>> Regards, Roald
>> [1] http://trac.openlayers.org/ticket/2318
> Roald,
> Any chance that this behavior could be controlled by an option to the
> layer definition. When I'm building an application is it nice to be able
> to debug it with a right click, but when I deploy it, I think the new
> behavior is likely to be preferred.
> -Steve W
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the Dev mailing list
