[OpenLayers-Dev] Error in Marker.js
Andreas Hocevar
ahocevar at opengeo.org
Tue Oct 27 09:46:57 EDT 2009
this has already been fixed - the offending change has been reverted.
Regards,
Andreas.
Ian Trotter wrote:
> Hi,
> The resolution of http://trac.openlayers.org/ticket/2258 seems to have
> introduced a bug with the event-handling for markers. It seems that
> the Marker.events property is no longer being set when a marker is
> initialised.
> As an example, you can see that
> http://openlayers.org/dev/examples/georss-markers.html no longer shows
> the markers, with an error message that marker.events is null.
> I worked around the error message by explicitly adding events property
> to the marker:
> marker.events = new OpenLayers.Events(marker,
> marker.icon.imageDiv, null);
> before trying to register events:
> marker.events.register("mousedown", feature, markerClick);
> It seems that the events property of Marker is no longer being defined
> in the constructor of the class.
> Is that intentional?
> - Ian
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
