[OpenLayers-Dev] OpenLayers SLD formatting question
Andreas Hocevar
ahocevar at opengeo.org
Wed Sep 2 17:57:56 EDT 2009
Hey Paul,
Paul Dziemiela wrote:
> Hi folks,
> Been putting together a SLD library system and wanting to use the results in
> OpenLayers. From what I see the singular expectation of OpenLayers is that
> SLD documents will follow the structure of
> <sld:StyledLayerDescriptor ... >
> <sld:NamedLayer>
> <sld:Name>Foo</sld:Name>
> <sld:UserStyle>
> <sld:Name>Swamp</sld:Name>
> <sld:FeatureTypeStyle>
> <sld:Rule>
> However, the SLDs produced by the recent version of uDig(1.1.1) instead
> create structures like
> <sld:StyledLayerDescriptor ...>
> <sld:UserLayer>
> <sld:LayerFeatureConstraints>
> <sld:FeatureTypeConstraint />
> </sld:LayerFeatureConstraints>
> <sld:UserStyle>
> <sld:Rule>
> I'm wondering if the current OpenLayers design is intended to be the only
> way to parse SLDs or if it's just a case of needing someone to do the work
> to accept other formats?
The latter. In the return object of Format.SLD, everything is prepared
for UserLayers already. They are just not being parsed yet.
> The uDig SLD should have some kind of name applied
> to the UserLayer I think.
According to the spec, this is not required.
> Seems like the SLD development in general has slowed to some degree of late.
> Has anything further come of Andreas Hocevar's work via 1531?
> http://trac.openlayers.org/ticket/1531
> I particularly like the idea of adding in the FeatureTypeStyle logic into
> the OpenLayers style object. It would be helpful to be able to target
> particular style rule sets onto particular geometry types.
Yeah, unfortunately these SLD and Style improvements lack funding, and
the proposed FeatureTypeStyle support would not change anything in the
Style object. That would be even more effort.
> I rummaged around but I can't see a way to set an ogc:filter to restrict by
> geometry type. Or is that wrong? Can the filter refer to the feature's
> geometry's CLASS_NAME? Or could I move the CLASS_NAME into a feature
> attribute called "GTYPE" or such?
If you want that in SLD, then SemanticTypeIdentifier would come close. I
am not aware of a way to do this with OGC filters.
But I am sure there are ways to do what you need in OpenLayers, outside
the SLD document. I do not have a clear picture of your use case though.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
