[OpenLayers-Dev] feature.geometry.bounds and feature.bounds
François Van Der Biest
francois.vanderbiest at camptocamp.com
Fri Sep 4 09:52:25 EDT 2009
OK, question #1 self-answered : OpenLayers.Feature.Vector already has
a bounds property ;-)
Let's move to question #2
F.
On Fri, Sep 4, 2009 at 3:46 PM, François Van Der
Biest<francois.vanderbiest at camptocamp.com> wrote:
> Hi list,
> Sometimes, we have to read some geodata in which the bounds are
> explicitly given (eg: GeoJSON, GML, and so on).
> This is cool because we don't have to compute it client-side.
> It also happens that we have no geometry but bounds.
> In this case, using Format.GML, I've had to patch OpenLayers to make
> it work again, see for instance http://trac.openlayers.org/ticket/2255
> The underlying question for this patch is : "is it reasonnable to add
> a bounds property to a feature when we have no geometry ?"
> Eric says it's fine, but I'd like your opinion on this.
> Going further, one could ask: what if we have to read geodata in which
> the geometry and the bounds exist ?
> Should these explicit bounds go to feature.geometry.bounds or to
> feature.bounds, or to both ?
> As of today, these bounds go to feature.geometry.bounds, but one could
> imagine that the server fails in calculating the correct bounds (OK, I
> have to admit that there's very little chance for this).
> Therefore, I propose that explicit bounds go to feature.bounds, while
> calculated bounds go to feature.geometry.bounds
> We could then imagine a feature.getBounds() accessor, which would
> return feature.bounds if it exists, else feature.geometry.getBounds().
> This method could also have an option to force the computing of bounds
> from the geometry.
> What's your opinion on this ?
> Thank's,
> F.
More information about the Dev
