[OpenLayers-Dev] cropped icons
ibrahim saricicek ibrahimsaricicek at gmail.com
Fri Sep 18 02:32:48 EDT 2009
Thanks, I think i should use gutter with mapserver...
I increased Metabuffer. Now i can see the whole symbol and label..
Regards..
On Thu, Sep 17, 2009 at 6:48 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Hi Ibrahim,
> you should not use gutter with tilecache. Instead, configure tilecache to
> use metatiles.
> Regards,
> Andreas.
> ibrahim saricicek wrote:
>> Hi all,
>> I'm using mapserver, tilecache, openlayers..
>> My symbols or the labels on the tile edges are cropped,
>> When i use on mapserver
>> "PARTIALS FALSE", the sybols on the edges are being dismissed. But i want
>> to show them all.
>> Then i used gutter on OpenLayers; but it doesn't work too..
>> new OpenLayers.Layer.WMS("MY Map",
>>                    "http://127.0.0.1:8080/cgi-bin/tilecache.cgi?",
>> {layers: 'MY_Map', format: 'image/png' , *gutter:50*},
>> You can see the problem on atteched screenshot..
>> What should i do to prevent those?
>> Thanks for any help in advance..
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090918/b9b33971/attachment.html
More information about the Dev mailing list
