[OpenLayers-Dev] Graticule control can't be deactivated
Fabian Patzke (OL)
listensammler at patzi.de
Thu Apr 1 08:24:05 EDT 2010
Graticule control dan't be deactivated
Fabian Patzke (OL) Fabian Patzke (OL) Apr 01, 2010; 01:54pm
first of all you guys made a huge step with 2.9RC1 many thanks.
So I started to work with it and test it.
I create a map with EPSG:25832, remembered to use proj4js ;) and added the
control like this:
var gratControl = new OpenLayers.Control.Graticule({
autoActivate: false
map.addControl(gratControl);
Everything is fine the control works and theres no prob besides the fact
that the control is active though I have set "autoActivate" to false. Also a
JS call like:
gratControl.deactivate();
does not work. Although the gratControl.active parameter tells me afterwards
that the control is deactiveted, but I can still see it in the map. Am I
missing something here or is this maybe a bug?
Greetings,
Fabian
View this message in context: http://n2.nabble.com/Graticule-control-can-t-be-deactivated-tp4836670p4836670.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
