[OpenLayers-Dev] SOS support
Eric Lemoine eric.lemoine at camptocamp.com
Sat Apr 3 04:26:51 EDT 2010
On Thursday, March 25, 2010, Tim Schaub <tschaub at opengeo.org> wrote:
> Bart van den Eijnden wrote:
>> Hi,
>> the example demonstrates the way the building blocks provided by the
>> library can be tied together, this is highly application-specific,
>> everybody will want to do it in a different way. The example is just
>> one way.
>> So what the library provides are the building blocks: 1) a protocol
>> for communicating with an SOS 2) formats to parse several SOS
>> responses and write out some requests
>> These can be used with the standard OpenLayers.Layer.Vector. This is
>> the way OpenLayers has been redesigned about 1 or 1,5 years ago,
>> because for every type a new Layer type was necessary in the past
>> (Layer.GML etc). With the new design, this is not necessary anymore.
>> It is a much cleaner design.
>> So, to answer your question, there won't be an OpenLayers.Layer.SOS.
>> An application builder is responsible for tying the pieces together.
> Hey-
> Quick follow up on this.
> Personally, I don't think we should discourage the creation of new
> layers that use specific formats, protocols, and strategies.
> The vector behavior design was supposed to encourage reuse of common
> code rather than discourage new specific layer types.
> Not sure how others feel, but if someone wanted to create a specific SOS
> layer, I'd be in favor of including it.
> Disclaimer: I have no idea if someone could create an SOS layer that
> would be useful in multiple applications.
Hi
Adding convenience classes makes sense to me. This "vector behavior"
stuff can look scary to newcomers, and convenience classes could
improve the situation I think.
For example we could have a WFS layer, pre-configured with a WFS
protocol and a BBOX strategy, and with which the user just needs to
set "url" and "featureNS" in the options passed to the constructor.
This layer could be OpenLayers.Layer.Vector.WFS, although I don't like
having four levels too much; but I guess this kind of details should
be discussed in a specific thread.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
