[OpenLayers-Dev] Bug when creation a map in a div with id like 'mapDIV' (2.9RC1)?
Fabian Patzke (OL) listensammler at patzi.de
Tue Apr 6 08:14:47 EDT 2010
bartvde wrote:
> Hi Fabian,
> thanks for pointing out the inconsistency, I've opened up a bug so we can
> tackle this in the future:
> http://trac.openlayers.org/ticket/2564
> Best regards,
> Bart
No problem, so my "bug" report had a little good side effect. Just to
clarify the map constructor also accepts a DOMelement as the first parameter
its just written wrong ;)
As far as I checked the code in map.js, both variants uses the same code:
  this.div = OpenLayers.Util.getElement(div);
So it just needs to be corrected in the DOC of the constructor settings.
Best wishes,
Fabian
View this message in context: http://n2.nabble.com/Bug-when-creation-a-map-in-a-div-with-id-like-mapDIV-2-9RC1-tp4857886p4858651.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
