[OpenLayers-Dev] [OpenLayers-Users] OpenLayers 2.9 Release
Candidate 1
Christopher Schmidt
crschmidt at metacarta.com
Sat Apr 10 11:44:59 EDT 2010
On Sat, Apr 10, 2010 at 05:06:55PM +0200, Bart van den Eijnden wrote:
> You're right Arnd, something went wrong there.
> Chris, any ideas? The version number of the rc2 build is still 10129 just like rc1.
> RC2 should be 10186.
> http://trac.openlayers.org/changeset/10186
The VERSION_NUMBER isn't changed unless OpenLayers.js is changed,
so that's not going to be the best way to track it. However, I did
confirm that there was a typo in my running of the build script. I've
re-run it, and a new RC2 build is available from /api/ and
/download/ (in the same locations).
-- Chris
> Best regards,
> Bart
> On Apr 10, 2010, at 2:41 PM, Arnd Wippermann wrote:
> > Hi Bart,
> > It seems, that the RC2 release is the same as RC1. I have used
> > <script src="http://openlayers.org/api/2.9-rc2/OpenLayers.js"></script>
> > and then downloaded the zip. But in both cases I get the RC1.
> > Arnd
More information about the Dev
