[OpenLayers-Dev] allOverlays question
bartvde at osgis.nl
bartvde at osgis.nl
Tue Apr 13 05:47:47 EDT 2010
Hi Eric,
my map definition has the following set:
var map = new OpenLayers.Map({
fractionalZoom: true,
maxResolution: GeoServices.MapMaxResolution,
projection: GeoServices.MapProjection,
units: GeoServices.MapUnits,
allOverlays: true,
maxExtent: GeoServices.MapMaxExtent
However, since my layers come from a Web Map Context (WMC) document, it
always has numZoomLevels set in the Extension:
<Extension>
<ol:maxExtent xmlns:ol="http://openlayers.org/context"
minx="0.000000000" miny="300000.0000" maxx="300000.0000"
maxy="625000.0000"/>
<ol:transparent
xmlns:ol="http://openlayers.org/context">TRUE</ol:transparent>
<ol:numZoomLevels
xmlns:ol="http://openlayers.org/context">18</ol:numZoomLevels>
<ol:units xmlns:ol="http://openlayers.org/context">m</ol:units>
<ol:isBaseLayer
xmlns:ol="http://openlayers.org/context">false</ol:isBaseLayer>
<ol:displayInLayerSwitcher
xmlns:ol="http://openlayers.org/context">true</ol:displayInLayerSwitcher>
<ol:singleTile
xmlns:ol="http://openlayers.org/context">true</ol:singleTile>
</Extension>
So I guess this won't work for me?
Best regards,
Bart
> On Tue, Apr 13, 2010 at 10:00 AM, <bartvde at osgis.nl> wrote:
>> Hi list,
>> I am tracking down an issue in my application. I am using allOverlays
>> true
>> on the Map object. When I start up my application, a layer with no scale
>> info set is as the lowest in the stack and hence acts as the "base"
>> layer.
>> However, I have a control which raises this layer (a marker layer) to
>> the
>> top, and then another (WMS) layer acts as the "base" layer. This layer
>> is
>> however scale-dependent, which means the map is not zoomable anymore
>> after
>> 1:500.000.
>> Is there a way around this, or is this a side-effect of allOverlays? Do
>> I
>> need to resort back to my dummy base layer?
> Hi Bart
> Do you have resolutions or resolution information set in the map?
> I think my patch for <http://trac.openlayers.org/ticket/2427> would
> help you. With my patch if your layer options include maxResolution
> (or minResolution) and doesn't include numZoomLevels (which is the
> default), then no attempt to calculate resolutions based on the
> maxResolution value will be done, and the resolution data from the map
> will be used.
> Tell me if you need further information.
> PS: I have a complete description of my patch, but I'm holding it
> until 2.9 is released.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
More information about the Dev
