[OpenLayers-Dev] XMLHttpRequest.js license
Paul Spencer
pspencer at dmsolutions.ca
Wed Apr 21 07:59:46 EDT 2010
Bart,
based on my experience in other projects, it should be sufficient to include this in a comment at the top of XMLHttpRequest.js with a brief explanation of the issue and then we should be good to go.
For the record, I am wondering why it is a problem to include LGPL code in OpenLayers if it is used as a Library (unmodified)? Roald's remark just seems to be that we *might* have a GPL infringement, that doesn't seem terribly convincing to me that there is a problem that we should be concerned about by including LGPL code. Can anyone elaborate on whether this is actually a problem, what the problem is, or if there is not, in actual fact, a problem with including LGPL code.
Cheers
Paul
On 2010-04-21, at 5:11 AM, bartvde at osgis.nl wrote:
> Hi devs,
> since XMLHttpRequest.js had changed its license from Apache license to
> LGPL (see also http://trac.openlayers.org/ticket/2065), we have problems
> with rolling in new versions of the library (see also Roald's remark about
> GPL infringement in that particular ticket).
> Since the author is based in The Netherlands, I decided to contact him to
> ask if we would consider relicensing to the previous Apache license, and
> he agreed to this (see below).
> Does this mean we will be able to upgrade XMLHttpRequest in the future, or
> do we need more from him?
> Best regards,
> Bart
> ------------------------- Oorspronkelijk bericht -------------------------
> Onderwerp: Re: XMLHttpRequest.js license
> Van: "Sergey Ilinsky" <sergey at ilinsky.com>
> Datum: Wo, 21 april, 2010 10:45 am
> Aan: bartvde at osgis.nl
> Bart,
> I authorize OpenLayers to get the latest version of XMLHttpRequest.js
> library and use it under Apache license (Just replace the license note in
> the file). Is the written confirmation sufficient?
> Yes, I am based in the Netherlands, living in Amsterdam. Have worked for
> Backbase for 3 years, now working at Nedstat. In my free time I am busy with
> Ample SDK <http://www.amplesdk.com/>, new JavaScript GUI Framework (also
> open source) which among other features such as support for XUL also bring
> SVG to all browsers and more.
> Do you arrange some meet-ups with people working on OpenLayers or other
> client-side developers in Amsterdam? I would be interested in
> getting acquainted with you and others.
> Sergey/
> On 21 April 2010 07:29, <bartvde at osgis.nl> wrote:
>> Hi Sergey,
>> the OpenLayers project (http://www.openlayers.org) uses your
>> XMLHttpRequest.js library, but now has trouble upgrading because of your
>> license change from Apache license to LGPL.
>> Would you consider relicensing your library under Apache for the
>> OpenLayers project?
>> TIA.
>> Btw, I see you are also based in The Netherlands?
>> Best regards,
>> Bart
> <untitled-[2].html>_______________________________________________
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the Dev
