[OpenLayers-Dev] XMLHttpRequest.js license
christopher.schmidt at nokia.com
Wed Apr 21 09:06:23 EDT 2010
On Apr 21, 2010, at 5:11 AM, ext bartvde at osgis.nl wrote:
> Hi devs,
> since XMLHttpRequest.js had changed its license from Apache license to
> LGPL (see also http://trac.openlayers.org/ticket/2065), we have problems
> with rolling in new versions of the library (see also Roald's remark about
> GPL infringement in that particular ticket).
> Since the author is based in The Netherlands, I decided to contact him to
> ask if we would consider relicensing to the previous Apache license, and
> he agreed to this (see below).
> Does this mean we will be able to upgrade XMLHttpRequest in the future, or
> do we need more from him?
This seems sufficient to me. I'll double-check with John, but I see no problem with this. Thanks for sending the email! (I assume this isn't a blocker for 2.9; I don't have a problem with a 2.9.1 or quick 2.10 to fix a number of small things that people have brought up if there is sufficient interest.)
-- Chris
> Best regards,
> Bart
> ------------------------- Oorspronkelijk bericht -------------------------
> Onderwerp: Re: XMLHttpRequest.js license
> Van: "Sergey Ilinsky" <sergey at ilinsky.com>
> Datum: Wo, 21 april, 2010 10:45 am
> Aan: bartvde at osgis.nl
> Bart,
> I authorize OpenLayers to get the latest version of XMLHttpRequest.js
> library and use it under Apache license (Just replace the license note in
> the file). Is the written confirmation sufficient?
> Yes, I am based in the Netherlands, living in Amsterdam. Have worked for
> Backbase for 3 years, now working at Nedstat. In my free time I am busy with
> Ample SDK <http://www.amplesdk.com/>, new JavaScript GUI Framework (also
> open source) which among other features such as support for XUL also bring
> SVG to all browsers and more.
> Do you arrange some meet-ups with people working on OpenLayers or other
> client-side developers in Amsterdam? I would be interested in
> getting acquainted with you and others.
> Sergey/
> On 21 April 2010 07:29, <bartvde at osgis.nl> wrote:
>> Hi Sergey,
>> the OpenLayers project (http://www.openlayers.org) uses your
>> XMLHttpRequest.js library, but now has trouble upgrading because of your
>> license change from Apache license to LGPL.
>> Would you consider relicensing your library under Apache for the
>> OpenLayers project?
>> TIA.
>> Btw, I see you are also based in The Netherlands?
>> Best regards,
>> Bart
> <untitled-[2].html><ATT00001..txt>
More information about the Dev
