[OpenLayers-Dev] Popup on line feature displayed in wrong location
MostlyBaldEagle
MostlyBaldEagle at shaw.ca
Fri Apr 30 13:46:23 EDT 2010
When moving a point feature which has a line feature connected to it the
popup for the line feature sometimes shows up in the location where the line
was before the move. This can be easily reproduced with the following
example.
http://n2.nabble.com/forum/FileDownload.jtp?type=n&id=4986912&name=test_2_8.htm
test_2_8.htm
I added a control panel in the top left to be able to change from selection
to drag mode. The icons might be a bit misleading :-)
Try moving a few markers and then go to select mode and select the line
features. Some popups will show up in the correct location and some will
not. I have seen this in both 2.8 and 2.9.
Regards
Olaf
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Popup-on-line-feature-displayed-in-wrong-location-tp4986912p4986912.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
