[OpenLayers-Dev] Panel control: strange behavior when using TYPE_TOOL and TYPE_BUTTON
Xavier Mamano (jorix) xavier.mamano at gmail.com
Sun Aug 1 08:21:49 EDT 2010
Panel: strange behavior when using TYPE_TOOL and TYPE_BUTTON
Hi devs,
In a panel usually the buttons remain deactivate, and no problems.
But when buttons are activated, and then a tool is activated, the active
buttons are also deactivated.
This occurs, for example using NavigationHistory (after moving the map) and
press a tool, then the NavigationHistory are shown as deactivated but when
presses button it act properly, ups!
It also happens to set up a drawing toolbar with a button to save that is
activated by adding features, save button is deactivate when changing the
drawing tool, ups!
Someone else has encountered similar problems?
I opened the ticket http://trac.openlayers.org/ticket/2764, before placing
it in review, wanted to know the opinion of the developers.
Regards,
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Panel-control-strange-behavior-when-using-TYPE-TOOL-and-TYPE-BUTTON-tp5360809p5360809.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
