[OpenLayers-Dev] strokeDashstyle and KML
Andreas Hocevar
ahocevar at opengeo.org
Wed Aug 4 04:34:07 EDT 2010
Can you provide a working example (with the KML in question) that shows what you are doing?
Thanks,
Andreas.
On Aug 4, 2010, at 10:29 , Thomas PAPIN wrote:
> Hello,
> It's seems not possible to apply a strokeDashstyle from a KML layer or I didn't find how to do ? is that correct ?
> The only solution is to add the style after loadend event manually ?
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
