[OpenLayers-Dev] strokeDashstyle and KML
Thomas PAPIN
thomas.papin at gmail.com
Wed Aug 4 05:34:23 EDT 2010
You mean with a stylemap ?
new ... StyleMap({
strokeDashstyle: "${myownstyle}",
Add use Rule to apply just to my circles
2010/8/4 Andreas Hocevar <ahocevar at opengeo.org>
> On Aug 4, 2010, at 11:19 , Thomas PAPIN wrote:
> > So if I want to change the strokeStyle, I need to change it manually
> after loading the KML
> > or (but I don't like that) edit Format/Kml.js and add a hack to support a
> non-official tag
> Or you use rule based styling instead of KML's inline styles.
> Andreas.
> > Thomas
> > Hi,
> > there is no strokeStyle in KML. See
> http://code.google.com/apis/kml/faq.html#linestyle
> > Regards,
> > Andreas.
> > On Aug 4, 2010, at 11:05 , Thomas PAPIN wrote:
> > > I want to draw a circle with dash stroke
> > > <kml xmlns="http://www.opengis.net/kml/2.2">
> > > <Document>
> > > <name>My Layer</name>
> > > <description>My Layer</description>
> > > <Style id="circles">
> > > <LineStyle>
> > > <width>1</width>
> > > <color>AAAA0101</color>
> > > <strokeStyle>dashlong</strokeStyle> <-------- Here what I want
> to be able to do
> > > </LineStyle>
> > > </Style>
> > > <Placemark>
> > > <name>Circles</name>
> > > <description>Circles</description>
> > > <styleUrl>#circles</styleUrl>
> > > <Polygon>
> > > <outerBoundaryIs>
> > > <LinearRing>
> > > <coordinates>
> 57.524815584992,-21.089077666611,0
> 57.491623770767,-20.775797326738,0
> 57.401366068943,-20.47264076493,0
> 57.257078399726,-20.188726311404,0
> 57.063349621694,-19.932548767663,0
> 56.826161736521,-19.711737565644,0
> 56.552700712164,-19.532843001926,0
> 56.251143522419,-19.401155031576,0
> 55.930426526423,-19.320558337236,0
> 55.6,-19.293426628671,0
> 55.269573473577,-19.320558337236,0
> 54.948856477581,-19.401155031576,0
> 54.647299287836,-19.532843001926,0
> > > Can you provide a working example (with the KML in question) that shows
> what you are doing?
> > > Thanks,
> > > Andreas.
> > > On Aug 4, 2010, at 10:29 , Thomas PAPIN wrote:
> > > > Hello,
> > > > It's seems not possible to apply a strokeDashstyle from a KML layer
> or I didn't find how to do ? is that correct ?
> > > > The only solution is to add the style after loadend event manually ?
> > > > _______________________________________________
> > > > Dev mailing list
> > > > Dev at openlayers.org
> > > > http://openlayers.org/mailman/listinfo/dev
> > > Andreas Hocevar
> > > OpenGeo - http://opengeo.org/
> > > Expert service straight from the developers.
> > > Dev mailing list
> > Andreas Hocevar
> > Dev mailing list
> Andreas Hocevar
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100804/8f10233d/attachment.html
More information about the Dev
