[OpenLayers-Dev] Multiple WMS Layers (isBaselayer = false) +
Zoom
Thomas PAPIN
thomas.papin at gmail.com
Fri Aug 6 05:50:04 EDT 2010
Thanks :) it's working perfectly !
2010/8/6 Bart van den Eijnden <bartvde at osgis.nl>
> Try and use allOverlays: true on your map options.
> Best regards,
> Bart
> Looking for flexible support on OpenLayers or GeoExt? Please check out
> http://www.osgis.nl/support.html
> OSGIS
> bartvde at osgis.nl
> On Aug 6, 2010, at 11:24 AM, Thomas PAPIN wrote:
> No idea ?
> 2010/8/5 Thomas PAPIN <thomas.papin at gmail.com>
>> Hello,
>> I have a map with several WMS layer. isBaseLayer is set to FALSE in order
>> to be able to display two layers in the same time.
>> But when I do this, when I do a zoom, only the first layer is zooming, the
>> others are keeping the same zoom :-(
>> Thomas
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100806/4bc902a7/attachment.html
More information about the Dev
