[OpenLayers-Dev] Openlayer & Routing engine
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Mon Aug 16 12:07:53 EDT 2010
On Aug 16, 2010, at 11:59 AM, ext Leonardo Gaona wrote:
> I want to develop an application like yournavigation using the gosmore routing engine, along with OpenLayers and some server side glue code. could I run gosmore on Windows to develop the application or only available for linux?
You'll need to ask this on a mailing list related to Gosmore.
The OSM Routing list is probably a solid choice.
Good luck.
-- Chris
> Could someone explain about this <ATT00001..txt>
More information about the Dev mailing list
