[OpenLayers-Dev] Patrch for getting vector drawing working over
the 180 line going.
Tim Schaub
tschaub at opengeo.org
Thu Aug 19 13:27:48 EDT 2010
On 8/18/10 3:25 PM, Phil Scadden wrote:
>> Please don't try to bake in any assumptions about heading in a line
>> segment. Our geometry model is based on coordinates on a plane. My
>> opinion is that "crossing the dateline" is application logic.
My comment here was meant to say that I would not be in favor of any
change that made it so the distance between (-170, 0) and (170, 0) was
20 (by default).
> So when I try to draw say a zoom rectangle across the date line, or
> measure a distance between two points which happen to be on opposite
> sides of the dateline, how do I put that logic in my application to cope
> with this without altering OL? Or draw a selection polygon to choose
> some data in a WFS layer? This is where problems occurs. The reason for
> looking at the renderer approach is that there remain problems with just
> doing it in the handlers. Obviously its pointless for me to continue
> work on renderer model if it wont be accepted into OL, so I'll the study
> the remaining issues with the handlers in Andreas's patch today. But I
> dont believe there is a solution to the problem without altering OL.
>> Geometries should be split when the user tries to draw beyond the domain
>> of the coordinate system.
> Well to be honest I am sick to death of geometry models based on a plane
> when we live on a spherical earth, and its especially a pain when you
> live close to the 180 lines and nightmare if you are working near the
> pole. I would really like to see OL get onto a sphere. There is dearth
> of tools for working on a sphere. Our inhouse software always manages it
> because its taken into account from day 1 but reengineering flat earth
> software to work with real world geometry is a mega pain. Would you be
> so keen on applications having to split geometry if you lived on the 180
> line?
I understand the frustration. If you can get involved in (or have
suggestions for) OpenLayers 3.0 with regard to a different geometry
model (or changes at some other level), that would be great.
Tim
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
