[OpenLayers-Dev] Closure Compiler for OpenLayers 3.x
Gregers Gram Rygg
gregersrygg at gmail.com
Fri Dec 3 09:40:35 EST 2010
Thanks for the thorough explanation of Closure compiler for OpenLayers.
I would very much like to have support for advanced optimizations for
Closure compiler in OpenLayers v3, and would like to volunteer to the
massive changes I suppose is needed. Any ideas how much of the code
that can be rewritten automatically with scripts?
Regards,
Gregers
2010/12/3 Klokan Petr Přidal <klokan at klokan.cz>:
> Hello Peter,
> I have seen your ticket. OpenLayers 2.x can be compiled only with
> SIMPLE OPTIMIZATION. Then the Closure Compiler is just another
> minimizer, slightly better then JSMIN. No big deal, beside 20% smaller
> file size for existing build process. ;-)
> What I am suggesting with the blog post is to write the code of
> OpenLayers 3.x in a way to allow ADVANCED_OPTIMIZATION of of the code.
> This would bring:
> - Much better code optimization - resulting in even smaller file size.
> - Documentation with JSDoc Tags is validated and meaningful - code is
> under better control
> - Possibility to strip all unused parts of the OpenLayers library when
> it is compiled together with the final application. No need to choose
> in advance what functionality I want in the building profiles.
> Dependencies are solved by the compiler automatically.
> - Possibility to compile OpenLayers only for particular use - Mobile
> WebKit browser, Quirks vs Standards mode, etc.
> - Debugging with FireBug even for the compiled version of the source code.
> - Generation of dynamically loadable modules, to speed up loading of
> the library.
> Details are in the blog post, including tips on how to do that - based
> on our practical experience with Google Closure Compiler from another
> projects. I can write also examples to demonstrate the described
> features.
> The question for community is mostly:
> - Are we willing to follow the JavaScript Style Guide, which is
> necessary for the advanced compilation: http://bit.ly/9lETMA
> - Do we want to write the correct JSDoc tags according to: http://bit.ly/3UNSlI
> These are the decisions for OpenLayers 3.0, which should be done
> before the one week active coding session is going to happen. BTW I am
> keen to participate if it's going to be in Europe.
> Regards,
> Klokan Petr Pridal
> 2010/12/2 Peter Robins <openlayers at peterrobins.co.uk>:
>> I set up a ticket on this subject a couple of weeks ago, as it didn't
>> seem to me to be limited to any particular version of OL and there's
>> no reason why people can't start using it for their builds
>> straightaway (though not mentioned in the ticket, I am also using GCC
>> for my proj4js builds, with similar results)
>> http://trac.osgeo.org/openlayers/ticket/2900
>> Some further comments at http://trac.osgeo.org/openlayers/ticket/2925
>> 2010/12/2 Klokan Petr Přidal <klokan at klokan.cz>:
>>> Dear OpenLayers developers,
>>> I wrote a blog post which is summarizing what can the open-sourced
>>> Google Closure Compiler do for OpenLayers 3.0, how it can be done and
>>> what are the implications.
>>> Let's discuss this subject with the community. I am keen to get a
>>> feedback and know what people think about that.
>>> Please read the blog post:
>>> http://blog.klokantech.com/2010/12/closure-compiler-for-openlayers-3x.html
>>> And send comments...
>>> Regards,
>>> Klokan Petr Pridal
>>> P.S.
>>> I promised Tim Schaub at FOSS4G in Barcelona to publish such a post,
>>> but it took me a bit longer then I expected...
>>> http://www.mapranksearch.com/
>>> http://www.maptiler.org/
>>> http://www.oldmapsonline.org/
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Dev mailing list
> Dev mailing list
More information about the Dev
