[OpenLayers-Dev] reproject using vector and protocol (WFS) is not working
Steven M. Ottens steven at minst.net
Wed Feb 3 04:26:00 EST 2010
Hi all,
I'm trying to access a WFS in epsg:30800, while the background layer and
all other WFS's are in epsg:4258. I've configured all WFS's using Vector
and protocol.WFS. I've set the projection in the layer definition, and
the WFS request does contain the correct epsg code, but the coordinates
are still in 4258. I checked the Vector class and didn't see anything
related to projection, am I correct in assuming that Vector.js together
with the WFS protocol doesn't support reprojecting features? If so
should I create a ticket, since WFS.js does support it
(http://trac.openlayers.org/ticket/1406)
regards,
Steven
Configuration of the working WFS:
var wfs_nl_cp = new OpenLayers.Layer.Vector(
     "The Netherlands: CP",
         strategies: [new OpenLayers.Strategy.BBOX({resFactor: 1})],
         visibility: true,
         projection: new OpenLayers.Projection("EPSG:4258"),
         protocol: new OpenLayers.Protocol.WFS({
             version: "1.1.0",
             srsName: "EPSG:4258",
             extractAttributes:true,
             url:
"http://esdin.geodan.nl/fgi/Kadaster/deegree-wfs/services",
             featurePrefix: "CP",
             featureType: "CadastralParcel",
             featureNS:
"urn:x-inspire:specification:gmlas:CadastralParcels:3.0",
             geometryName: "geometry",
             maxFeatures: "100",
             sortBy: "label", //not supported
             schema:
"http://esdin.fgi.fi/esdin/Kadaster/deegree-wfs/services?request=DescribeFeatureType&version=1.1.0&service=WFS&typeName=CP:CadastralParcel&namespace=xmlns(xmlns:CP=urn:x-inspire:specification:gmlas:CadastralParcels:3.0)"
and the not working WFS:
     var wfs_se_gn = new OpenLayers.Layer.Vector(
     "Sweden: GN",
         visibility: false,
         styleMap: pointStyles,
         projection: new OpenLayers.Projection("EPSG:30800"),
             version: "1.1.0",
             srsName: "EPSG:30800",
             url: "http://esdin.geodan.nl/fgi/NLSS/geoserver_esdin/wfs",
             featurePrefix: "esdin",
             featureType: "geographicalNames",
             featureNS: "http://www.metainfo.se/esdin",
             geometryName: "SHAPE",
             schema:
"http://esdin.geodan.nl/fgi/NLSS/geoserver_esdin/wfs?&request=DescribeFeatureType&version=1.1.0&typeName=esdin:geographicalNames"
The post request generated with the second layer is:
|<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
version="1.1.0" xsi:schemaLocation||="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
xmlns:xsi="http://www.w3.org||/2001/XMLSchema-instance">
<wfs:Query typeName="esdin:geographicalNames" srsName="EPSG:30800"
xmlns:esdin||="http://www.metainfo.se/esdin">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:BBOX>
<ogc:PropertyName||>SHAPE</ogc:PropertyName>
<gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:30800">
<gml||:lowerCorner>-45.25 16.72265625</gml:lowerCorner>
<gml:upperCorner>67.25 85.27734375</gml:upperCorner||>
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>|
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100203/5eae706a/attachment.html
More information about the Dev mailing list
