[OpenLayers-Dev] Markers and Vector Layer conflict
Alex G. unseen.wizard at gmail.com
Thu Feb 4 07:43:05 EST 2010
Hi all,
I am probably having a conflict problem with some of my layers. I currently
have 3 layers active on my installation:
- a layer containing the data from a shapefile (running WMS)
- a vector layer where users can draw
- a layer dedicated to markers.
I have noticed that if I place a marker, I cannot interact with it
afterwards unless I hide the vectors layer. The order is correct, I load
first the shp layer, then the vector one and then the markers one.
I include here some of my code in hope that it will help, it's mostly from
examples on openlayers so there's really nothing new.
            map = new OpenLayers.Map('map',{maxExtent: new
OpenLayers.Bounds(195441.084706006,4171163.51662705,240142.089176109,4203199.94421431),
maxResolution: 120, units: 'dd'});
            layer = new OpenLayers.Layer.WMS( 'Landmass ', '
http://localhost:8585/cgi-bin/mapserv?map=/opt/fgs/apps/gmap-demo-cvs_MS_VERSION_54/htdocs/gmap75a.map&',
                layers: 'zak',
                format:'PNG',
                bbox:
'195441.084706006,4171163.51662705,240142.089176109,4203199.94421431',
                srs: 'EPSG:4326'
            lakegr_wms = new OpenLayers.Layer.WMS( 'Lakes',
                    layers: 'sedi',
                    transparent: 'true',
                    format: 'image/png'
                {isBaseLayer: false}
            vectors = new OpenLayers.Layer.Vector( 'Editable' );
            vectors.onFeatureInsert=function(feature) {
               var wkt=wktwriter.write(feature);
               console.log(wkt);
            map.addLayer(layer);
            map.addLayers([lakegr_wms,vectors]);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
                controls = {
                    point: new OpenLayers.Control.DrawFeature(vectors,
                                OpenLayers.Handler.Point),
                    line: new OpenLayers.Control.DrawFeature(vectors,
                                OpenLayers.Handler.Path),
                    polygon: new OpenLayers.Control.DrawFeature(vectors,
                                OpenLayers.Handler.Polygon),
                    drag: new OpenLayers.Control.DragFeature(vectors)
                for(var key in controls) {
                    map.addControl(controls[key]);
            map.zoomTo(1);
            var options = {
                hover: true,
                highlightOnly: true
            var select = new OpenLayers.Control.SelectFeature(vectors,
options);
            selectCtrl = new OpenLayers.Control.SelectFeature(vectors,
                    clickout: true,
                    onSelect: serialize
            map.addControl(select);
            map.addControl(selectCtrl);
            select.activate();
            selectCtrl.activate();
            var markers = new OpenLayers.Layer.Markers( 'Markers' );
            map.addLayer(markers);
Rest of the code is taken from the markers example on OpenLayers.
Can anyone think of any reason why they would conflict? I am thinking it has
something to do with clicks and some of the controls I use might be
conflicting although I can't see any Javascript errors.
Thanks in advance.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100204/01972a13/attachment.html
More information about the Dev mailing list
