[OpenLayers-Dev] maintenance releases
Matthias Sala
matthias at gbanga.com
Wed Feb 24 02:08:16 EST 2010
Bart van den Eijnden <bartvde at osgis.nl> schrieb:
>Picking up on an old thread, IIRC we had quite a bit of consensus on this.
>So what do we do for 2.9, a quick maintenance release or a normal full-blown release?
>Best regards,
>Bart
>On Sep 15, 2009, at 9:00 PM, Tim Schaub wrote:
>> Hey-
>> We periodically discuss releasing on a fixed schedule. Though a few
>> releases have come close to sticking to a schedule, my impression is
>> that it has been a tough to pull off. It is also my impression that the
>> release process feels onerous enough to enough people that we are
>> collectively avoiding it.
>> I'm interested in discussing doing more "maintenance" releases between
>> minor releases. What exactly would change about the release process [1]
>> I'm not sure, but the goal would be to make it less work overall.
>> While this might seem extreme, I'm curious what people would think about
>> kicking out maintenance releases *without* going through the release
>> candidate cycle. Taking this further, a maintenance release manager
>> could decide to stick to a schedule and release even if there were known
>> regressions.
>> While the result may be something of questionable value, I do think it
>> would bring some benefits. My impression is that there are a lot of
>> people running applications off the trunk currently. I also imagine a
>> fair number are running "sandbox" functionality or their own patched
>> versions. Having more frequent releases would not be that much
>> different than pegging applications to a specific version of the trunk.
>> I think all would agree this is safer than having an application run
>> off the head revision.
>> This would also have the benefit for contributors of more quickly seeing
>> their contribution in an official release - potentially encouraging more
>> contributions.
>> Obviously there would be details to work out about the process, but I
>> would suggest a pared down version of the major/minor release process -
>> with leeway for the maintenance release manager to decide on some
>> specifics (e.g. if all tests pass on this date, bump tickets, release,
>> and make notes about known issues).
>> Thoughts?
>> Tim
>> [1] http://trac.openlayers.org/wiki/Release/Procedure
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
>Dev mailing list
More information about the Dev
