[OpenLayers-Dev] Openlayers using ArcGIS Server 9.4 not working
using OGC WMS on Google Basemap
Kevin Jones
jonekev2 at isu.edu
Thu Feb 25 17:06:06 EST 2010
I was wondering if anybody has problems with OGS WMS not working while using
ArcGIS 9.4 Server? When overlaid with Google Maps, I get a parameter 'srs'
contains unacceptable value. I am trying not to use the rest service for a
project. I can get it to work on the Open layers base map but when other
base map services are turned on it pushes this error. I have including my
WMS Call below.
" Code "
var wms4 = new OpenLayers.Layer.WMS("OpenLayers WMS basemap right now",
"http://geoinfo8.lib.uidaho.edu/ArcGIS/services/elevation/LiDAR_projectBound
aries/MapServer/WMSServer",
{ layers: '0',
TRANSPARENT: true
isBaseLayer: false,
opacity: 1.0
map.addLayer(wms4
Any help would be appreciated.
Thanks,
-Kevin j
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100225/33e95513/attachment.html
More information about the Dev
