[OpenLayers-Dev] IE 7 / 8 error: appendChild not supported
Cédric Moullet cedric.moullet at camptocamp.com
Fri Jan 1 12:43:23 EST 2010
Hi Eric,
I have tried with WMS and vector layers, and the same error appears:
http://dev.geoext.org/sandbox/cmoullet/ux/Printer/examples/PrinterExampleWMS.html
Cédric
2010/1/1 Eric Lemoine <eric.lemoine at camptocamp.com>
> 2010/1/1 Cédric Moullet <cedric.moullet at camptocamp.com>:
> > Hi,
> > I face a quite strange problem in map.js in IE 7 / 8.
> > Use case:
> > - Start
> > page:
> http://dev.geoext.org/sandbox/cmoullet/ux/Printer/examples/PrinterExample.html
> > - Click on "print" in the map toolbar
> > - Click on print in new window
> > - JS error appears: "Interface not supported" in line 921 of
> > map.js:
> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Map.js#L921
> > This works fine in FF, Safari and Chrome, so what could be the specific
> IE
> > problem ?
> have you tried with a different layer type? In case it's a
> Layer.OSM-specific issue.
> Cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
CTO Geospatial Camptocamp SA
Cédric Moullet
PSE A
CH-1015 Lausanne
www.camptocamp.com  / www.mapfish.org / twitter.com/cedricmoullet /
mapfishblog.blogspot.com/
+41 79 759 69 83 (mobile)
+41 21 619 10 21 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100101/38898b29/attachment.html
More information about the Dev mailing list
