[OpenLayers-Dev] Feature.style doesn't support contexts
Alexandre Dube adube at mapgears.com
Fri Jan 15 14:10:13 EST 2010
  I want to be able to save a OpenLayers.Style object or hash to a
vector feature.  Currently, in code, feature.style exists but you must
define a hash or else it doesn't work.
  My problem is that I want to be able to draw features to be used as
labels (floating text on the map).  To be able to do so, I need to
define a StyleMap with a context to display the label (I manually set
feature.isLabel on "featureadded") [1]
  That works well, but as soon as I want to "bind / save" the style to
the feature, I mean set feature.style, I need to set a hash and the
feature will be rendered without the contexts.
  I don't fully understand how the contexts, symbolizers, etc. work, but
my first guess would be to support OpenLayers.Style object directly in
the feature object.  Does that make sense ?
  Or maybe I'm doing it wrong and their's an other way of "labeling"
features.  My goal is to create features on a "cosmetic" layer with a
default style, then to be able to change the style of the features and
bind it to them (I mean without using rules on the layer level, but by
defining directly the feature style)
Many many thanks,
Alexandre
// [1] START
            var labelStyle = {
                label: "${name}",
                labelSelect: true,
                pointRadius: "${radius}"
            var styleOptions = {
              context: {
                  'name': function(feature) {
                      var szValue;
                      if (feature.attributes['name'] && feature.isLabel
=== true) {
                          szValue = feature.attributes['name'];
                      } else {
                          szValue = "";
                      return szValue;
                  'radius': function(feature) {
                      return (feature.isLabel === true) ? 0 : 6;
            var style = new OpenLayers.Style(
                OpenLayers.Util.applyDefaults(
                    labelStyle,OpenLayers.Feature.Vector.style["default"]),
                styleOptions
            var styleMap = new OpenLayers.StyleMap({
                "default": style
            layer = new OpenLayers.Layer.Vector(
                "Cosmetic", {'styleMap': styleMap});
// [1] END
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev mailing list
