[OpenLayers-Dev] central repo for v3
    Schuyler Erle
    schuyler at nocat.net
    Thu Jul  1 11:54:27 EDT 2010
To be totally honest, I loathe the github issue tracker, whereas I feel that Trac has treated us pretty darn well so far in that regard.
We can set up some kind of Git commit hook that automatically clones the Git repo when new code is checked in, and then checks that into the SVN repo behind Trac, so that the code browser stays up to date.
As for pull requests, I don't see a reason not to use the github tracker for that alone, but shouldn't emails go to the dev list? Or should we create a separate mailing list for that?
SDE
On Jul 1, 2010, at 8:40 AM, Tim Schaub wrote:
> On 7/1/10 3:25 AM, Bart van den Eijnden wrote:
>> Hey Tim,
>> what do we do with issues already opened in the OpenLayers Trac for Milestone 3.0?
> I'm open to whatever people want to do with regard to issue tracking.  I
> can't imagine anyone wants to copy tickets from one place to another.
> So I'd guess the consensus would be to keep managing the existing 3.0
> tickets in Trac.  We can open a discussion on it if others think otherwise.
> My suggestion was just to use the GitHub issue tracker for pull
> requests.  Again, we can disable the GitHub issue tracker if it feels
> too scattered to others.  We can also manage pull requests with email
> only (I'll be sending core committers information on where pull requests
> get sent).  I delete a lot of email, so I was suggesting opening a
> ticket to record a pull request.
> Tim
>> Best regards,
>> Bart
>> On Jul 1, 2010, at 6:20 AM, Tim Schaub wrote:
>>> And I should add, it's open season on deprecated code!  If you're handy
>>> with git, fork the central repo, look for "deprecated" or "3.0" and
>>> start hacking.  Make small, coherent changes.  Run tests to make sure
>>> they still pass.  Then send pull requests.
>>> Until we settle on a process, you should also open a ticket
>>> (http://github.com/openlayers/openlayers/issues *) and describe your
>>> changes.  This may end up being easier to deal with than pull requests.
>>> Don't be shy with those forks:
>>> http://github.com/openlayers/openlayers/network/members
>>> Tim
>>> * I don't mean to imply that all new OL issues should be put here.  And
>>> in fact nothing related to 2.x should be opened here.  If it gets too
>>> scattered, we should talk about disabling the GitHub issue tracker.  But
>>> I do think that as long as we're trying git&  GitHub for v3 development,
>>> we should see how the whole thing works for us.  (Personally, I don't
>>> really like the issue tracker, but I'm open to trying it.)
>>> On 6/30/10 3:56 PM, Tim Schaub wrote:
>>>> Hey-
>>>> As discussed in the IRC meeting on OL3, we'll be trying out git for
>>>> development toward 3.0 and are hosting the central repository on GitHub.
>>>> The current svn trunk committers that have GitHub accounts have been
>>>> added as collaborators for that repository.  Anybody can fork, make
>>>> changes, and send pull requests.  (Apologies to early forkers/watchers
>>>> for deleting and recreating the repository before.)
>>>> The readme-dev.md [1] at the repository root describes the process for
>>>> making changes to the central repository.  This is relevant to current
>>>> trunk committers.  As we go along, we'll work on a process that works
>>>> for everyone (or at least works well).
>>>> Only the first section of that document will be relevant for most folks.
>>>>   The part on merging changes from subversion is only relevant for
>>>> people who will be pulling in 2.x changes.
>>>> That's it for now.  Discussion welcome.
>>>> Tim
>>>> [1]: http://github.com/openlayers/openlayers/blob/master/readme-dev.md
>>> Tim Schaub
>>> OpenGeo - http://opengeo.org
>>> Expert service straight from the developers.
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> Dev mailing list
More information about the Dev
