[OpenLayers-Dev] github attempts
Frederic Junod frederic.junod at camptocamp.com
Mon Jul 5 09:56:26 EDT 2010
Hello,
Sorry for the mess, I'm a git beginner ...
I'll now work on the central repository for all the trivial stuff
(remove deprecated code, ...) and in my fork for the mid-long term
changes.
/me now reading http://progit.org/book/
bye
fredj
On Mon, Jul 5, 2010 at 6:38 AM,  <christopher.schmidt at nokia.com> wrote:
> On Jul 4, 2010, at 6:45 PM, ext Tim Schaub wrote:
>> On 7/4/10 8:33 AM, christopher.schmidt at nokia.com wrote:
>>> On Jul 4, 2010, at 10:28 AM, ext christopher.schmidt at nokia.com wrote:
>>>> Yo,
>>>> So, in testing github out, I:
>>>> 1. Forked openlayers/openlayers. (I did this a week ago)
>>>> 1a. Since my fork was out of date, I did:
>>>>        git pull git at github.com:openlayers/openlayers.git master
>>>>        git push
>>>>    To update my fork.
>>>> 2. Made some changes in my fork, and pushed them
>>> Though I now see that fredj had already made the same changes. Curses!
>>> fredj, I think you need to be pushing to the master repo more often :)
>>> I assume you have access; is there a reason to be way out on a branch
>>> like you are?
>> As far as I can tell, fredj has been using the online fork queue tool to
>> cherry pick commits from his fork, replaying these on the central repo.
> The WMS Untiled commits --
>  http://github.com/fredj/openlayers/commit/66904e7346fe76f7b13ccf3763ad84ad73d3082b
> appear to not be in the main openlayers/openlayer repo, unless
> I'm missing something. Does that seem accurate? (This is the change
> that I'm pretty sure I duplicated.)
>>  The result is that we have identical commits in the central repo and
>> fredj's repo, but they don't have the same SHA.  I think the same was
>> happening between cedric's fork and fredj's.  This is not that big a
>> deal, except that it makes the forks look artificially divergent - and
>> the central repository's history will look weird when we get things
>> properly merged.  Not that big a deal, things will get smoother as we
>> all get handier with git.
>> Chris, I think what you did looks good.  A couple things that you might
>> want to consider (depending on what makes sense to you).
>>     git remote add central git at github.com:openlayers/openlayers.git
>> If you run this in your repo, you can start using "central" to refer to
>> the central repo.  Then pulling recent changes from the central repo
>> would look like this:
>>     git pull central master
> Nothing really special here except that central is a fancy name for
> git at github.com:openlayers/openlayers.git, right?
>> This pull implicitly does a fetch and merge.  If you're pulling from a
>> somewhat untrustworthy remote, it probably makes sense to `git fetch`
>> and `git merge` independently.
> Gotcha. I mostly just 'pull' and hope git does magic :) Maybe someday
> this will bite me; for now, it seems to be doing the right things.
>> After you do this, you can poke around your .git directory to see how
>> things are configured (see .git/config for your named remote repositories).
>>     cat .git/refs/remotes/central/master
>> That's the SHA of the latest commit you have from the master branch in
>> the central repo.
>>     git show central/master
>> That's git's view of the latest commit you have from the master branch
>> in the central repo.  (And `git log central/master` for the full log.)
> Ah, so other tools get more if you actually set up a remote. Gotcha.
> I'll keep that in mind.
> -- Chris
>> Tim
>>> -- Chris
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
> Regards,
> Christopher Schmidt
> Nokia
> Dev mailing list
Frédéric Junod
Camptocamp SA
More information about the Dev mailing list
