[OpenLayers-Dev] Modifiy-Feature and Projection==>Bug in
WFST-Protocol
Carsten Eider
eider at fh-bingen.de
Thu Jul 8 01:30:49 EDT 2010
I can confirm your suggestion, but would call it a bug:
Look at the *s Insert says this.srsName=..., update does not
wfst.v1.js says
"Insert": function(feature) {
var node = this.createElementNSPlus("wfs:Insert");
****** hier wird was mit SRS gemacht *******
this.srsName = this.getSrsName(feature);
this.writeNode("feature:_typeName", feature, node);
return node;
"Update": function(feature) {
var node = this.createElementNSPlus("wfs:Update", {
attributes: {
typeName: (this.featureNS ? this.featurePrefix
this.featureType
if(this.featureNS) {
node.setAttribute("xmlns:" + this.featurePrefix,
this.featureNS);
// add in geometry
if (this.geometryName !== null) {
***** Hier scheint was zu fehlen *****
this.writeNode(
"Property", {name: this.geometryName, value:
feature}, node
00:08, schrieb Matt Priour:
> It sounds like you need to explicitly set the srsName in the WFST format
> options.
> Matt Priour
> Kestrel Computer Consulting
> Dipl. Inf. Carsten Eider wrote:
>> Hi list,
>> i am focussing a heavy bug being a hard showstopper in my project.
>> Problem:
>> We have developed a so called GeoEditor. It works fine if we stay in
>> EPSG:31467.
>> Now we switched to EPSG:900913 in order to be able to use GoogleMaps
>> EPSG:900913 is our internalProjection, whereas data is saved in the
>> backend as EPSG:31467.
>> There are nearly no problems while joining, splitting and creating
>> multipolygons.
>> The trouble starts, whenever we modify a feature using a
>> ModifyFeatureControl.
>> After removing or moving a point data is send to the server in
>> EPSG:31467 declared as EPSG:900913.
>> Data is send via WFS-T to our GeoServer-Backend.
>> Any suggestions where my problems come from?
>> TIA
>> Carsten
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
