[OpenLayers-Dev] Generating a valid WFS object
Tim Schaub
tschaub at opengeo.org
Fri Jul 9 17:48:43 EDT 2010
On 7/9/10 3:39 PM, Tim Schaub wrote:
... snip ...
> The featureNS corresponds to the workspace URL in GeoServer. If you
> have a workspace named "tiger" with the "http://postgis.org" URL, then
> use that URL. I don't think the workspace form should allow you to
> enter "http://postgis.org<http://postgis.org/>", but I could be wrong
> about that.
Ignore that bit above. I realize now it was an email formatting issue.
The rest still stands.
> You can only make requests for features on the same origin that is
> serving up your application (see "same origin policy"). If this page is
> served up from some place like http://ubuntu:8080/mymap.html then your
> layer will work with the url you provided for your WFS. If not, then
> you need to proxy GeoServer on the same origin that serves up your
> application (see "proxy geoserver on port 80" for details).
> Alternatively, you can set up a proxy next to your application loader
> and set OpenLayers.ProxyHost (see "openlayers faq").
> If your WFS is on the same origin as your application, use a relative
> URL so things will still work if you change domains.
> Finally, if your map is not in EPSG:32632, then you'll likely want to
> request features in your map projection. OpenLayers can transform
> coordinates client-side, but you'd need to provide the proj4js
> definition for EPSG:32632 and your map projection. If your OpenLayers
> map is also in EPSG:32632, then you're set.
> A guess at what might work for you (with some work):
> layer = new OpenLayers.Layer.Vector("WFS", {
> strategies: [new OpenLayers.Strategy.BBOX()],
> protocol: new OpenLayers.Protocol.WFS({
> url: "/geoserver/wfs",
> featureType: "poi",
> featureNS: "http://postgis.org",
> srsName: "EPSG:32632",
> version: "1.1.0"
> Hope that helps,
> Tim
> On 7/9/10 2:50 PM, Ulrik Balslev wrote:
>> Hi dev list,
>> Using OpenLayers& Geoserver for WMS seems straight forward and works
>> OK, but I cannot get it to work for WFS. I can't seem to create a valid
>> OpenLayers layer object.
>> A simple HTML page like this, gives a layer ('wfslayer'), that has no
>> features (no data).
>> Any hints? - Is it a security issue?
>> regs.
>> <html xmlns="http://www.w3.org/1999/xhtml">
>> <head>
>> <title>WFS test!</title>
>> <script src="./OpenLayers.js" type="text/javascript"></script>
>> <script>
>> var wfslayer;
>> OpenLayers.ProxyHost = "proxy.cgi?url=";
>> function init() {
>> wfslayer = new OpenLayers.Layer.Vector("WFS", {
>> url: "http://ubuntu:8080/geoserver/wfs",
>> featureType: "tiger:poi",
>> featureNS: "http://postgis.org<http://postgis.org/>",
>> version: "1.1.0"
>> </script>
>> </head>
>> <body onload="init()">
>> </body>
>> </html>
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
