[OpenLayers-Dev] Polygon vector inverting during zoom/pan,
bug in OL?
Andreas Hocevar
ahocevar at opengeo.org
Tue Jul 13 02:11:35 EDT 2010
please provide a minimal, self contained example with just the vector layer that shows the issue. We need this for debugging.
Thanks,
Andreas.
On Jul 12, 2010, at 19:10 , Alexei Peters wrote:
> Hey Everyone,
> We're wrapping up development of a small app and noticed a strange issue with some vector polygons.
> While zoomed out enough to see the entire polygon everything appears normal (http://dl.dropbox.com/u/8668064/Polygon%20normal.JPG). But after I zoom in several steps the polygon appears to invert and then display some strange behavior (http://dl.dropbox.com/u/8668064/Polygon%20inverted.JPG). In the images I've just barely panned the map and the polygon will flip from normal to inverted.
> It appears to happen in both FF and IE.
> Any suggestions on what is going on here?
> Any help is much appreciated.
> Cheers,
> Alexei
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
