[OpenLayers-Dev] iPhone javascript events
Andrew Marks
atm at amrx.net
Thu Jul 15 11:22:13 EDT 2010
>From your comment that I shouldn't modify handlers, controls, or
Events.js, I am taking that to mean the proper way to go about this
would be to implement a new handler which handles the touch events
instead of modifying Drag.js?
I'll start then by making a new Handler, MobileDrag, which does
basically the same thing as drag but using touch events instead of mouse
events. I'll probably need a new Control that uses that handler as well?
-Andrew
On 07/14/10 07:51, Tim Schaub wrote:
> Hey Andrew-
> Your efforts on this front are appreciated. I'd encourage you to work
> with a sandbox that is a copy of the trunk. If you keep your sandbox up
> to date with changes from the trunk, it will be easier to eventually
> create patches for the trunk.
> See the FAQ for details on creating and using a sandbox [1].
> What you are experimenting with is very similar to how others have
> gotten OpenLayers working on the iPhone. For inspiration, it may help
> to poke around the iOL library:
> http://projects.opengeo.org/mobile/browser/IOL/trunk/lib
> For OpenLayers 3.0, we'd like to be able to support more (browser)
> environments at a deeper level. In the end, you shouldn't have to
> modify handlers, controls, or (especially) Events.js.
> Keep us posted on your efforts,
> Tim
> [1]
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#HowdoIcreatemyownsandboxintheSVNrepository
> On 7/13/10 6:01 PM, Andrew Marks wrote:
>> Hello,
>> I would like to start a discussion about the proper inclusion of
>> special iphone-safari javascript events into OpenLayers. I am
>> attempting to add touch pan and zoom support to OpenLayers and while I
>> am doing it, I might as well do it in a way that is correct and can be
>> used by others. I'll talk about what I have done what I plan to do. I
>> am working with 2.9.1 (maybe I should work with trunk?)
>> What I have done: (Made touch map panning work)
>> First I added "touchstart", "touchend", "touchmove" to BROWSER_EVENTS in
>> Events.js
>> I then had to modify OpenLayers.Events.getMousePosition because the
>> position information in the touch events is in a different location,
>> specifically under "targetTouches" or "changedTouches" in the event.
>> Here is the code, added just before original return statement of
>> getMousePosition:
>> if (evt.type.match(/touch/)) {
>> var touches = evt.targetTouches;
>> if (touches.length< 1) {
>> touches = evt.changedTouches;
>> return new OpenLayers.Pixel(
>> (touches[0].pageX + this.element.scrolls[0]) -
>> this.element.offsets[0]
>> - this.element.lefttop[0],
>> (touches[0].pageY + this.element.scrolls[1]) -
>> this.element.offsets[1]
>> - this.element.lefttop[1]
>> return new ...
>> I then added three methods to OpenLayers.Handler.Drag:
>> touchstart: function (evt) {
>> evt.button = 1; //Pretend to be a left click.
>> return this.mousedown(evt);
>> touchmove: function(evt) {
>> return this.mousemove(evt);
>> touchend: function(evt) {
>> return this.mouseup(evt);
>> And now touch panning is working.
>> What I plan to do next is look at gesture events, specifically pinching
>> to zoom in and out.
>> I welcome all feedback to ensure this is done correctly. If I am going
>> about it incorrectly, let me know.
>> Thanks for your time,
>> Andrew Marks
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
