[OpenLayers-Dev] [BASURA]Re: WMS 1.3.0 issue
Xurxo Mendez
xmendez at udc.es
Fri Jul 16 04:13:37 EDT 2010
Hi Bart,
My apologies, my mistake. We have 2 OL versions and it was wrongly working
against 2.8. I was trying now to reproduce the errors to paste them here,
but it works perfectly, some links mislaid here... and as I saw Godiva2
people had a workaround I thought this was a known issue.
Sorry again and thank you, OL 2.9.1 works great!
Un saludo.
Xurxo Méndez Pérez
2010/7/15 Bart van den Eijnden <bartvde at osgis.nl>
> Hi,
> how are you specifying your WMS layer?
> It should be something like:
> new OpenLayers.Layer.WMS(null, url, {version: '1.3.0'}, {});
> Best regards,
> Bart
> On Jul 15, 2010, at 5:33 PM, Xurxo Mendez wrote:
> Hi bart,thank you for your answer.
> My problem is that when i specify '1.3.0' using WMS constructor openlayers
> creates a 1.1.x version of the layer (at least that os the version that
> appears in the getmap and getfeatureinfo requests),so i supposed it was due
> to that it didn't pass that 'if' condition as 1.3.0 layer.
> Best regards,
> Xurxo Mendez
> El 15 de jul de 2010, 4:53 p.m., "Bart van den Eijnden" <bartvde at osgis.nl>
> escribió:
> Hi,
> but parseFloat("1.3.0") yield 1.3, so what is the problem?
> Best regards,
> Bart
> On Jul 15, 2010, at 4:32 PM, Xurxo Mendez wrote:
> > Hi all, > In OL 2.9.1, I was trying to add a WMS layer to my map, setting
> its 'VERSION' parameter ...
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100716/d4de8549/attachment.html
More information about the Dev
