[OpenLayers-Dev] Issue with Layer.clone()
Adam Ratcliffe
adam at prema.co.nz
Fri Jul 23 03:22:26 EDT 2010
http://trac.openlayers.org/ticket/2749
Cheers
Adam
On 23/07/2010, at 5:49 PM, Tim Schaub wrote:
> On 7/22/10 8:59 PM, Adam Ratcliffe wrote:
>> Hi,
>> I'm having an issue with the OpenLayers.Layer.clone() method.
>> If the layer being cloned is a Vector layer, the source layer's
>> Protocol object will be copied by reference to the clone object. If
>> the cloned layer's destroy() method is called the shared Protocol
>> object will be destroyed and the source layer will cease to
>> function.
>> A possible solution would be to implement a clone() method on both
>> the Protocol and Strategy interfaces and use this method when cloning
>> the layer e.g.
> This is certainly an issue. Please open a ticket.
> Tim
>> for(var property in source) { var value = source[property]; if(value
>> !== undefined) { if(value.clone) { value = value.clone(); }
>> destination[property] = value; } }
>> Cheers Adam _______________________________________________ Dev
>> mailing list Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
More information about the Dev
