[OpenLayers-Dev] Problem with setVisibility on a Layer
sebgranel
sebastien.granel at gmail.com
Mon Jun 7 09:11:12 EDT 2010
Hi all, I am using dynatree to manage the layers instead of the layer
switcher because I have to much layers. So when a layer is checked in
dynatree I use the setVisible method. Everything seems good in the first
time but when I drag the map the layers are not moving at the same speed
that the base layer.
The most weird is when I do the same think with the layer switcher(even if
I can't check all the layers) it works great.
Can you tell me what exactly do the layer switcher or do you know another
way to make it works with dynatree ?
Thanks!
Ps : Sorry for my poor english
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-setVisibility-on-a-Layer-tp5148917p5148917.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
