[OpenLayers-Dev] using custom renderer on Layer.Vector
Slawomir Messner
slawomir.messner at staff.uni-marburg.de
Thu Jun 10 03:57:07 EDT 2010
Ok, the last mail was maybe a little short. We do it like this:
renderers: ["REDESVG", "SVG", "VML"]
As you see we use rendereS and an array, so for you it would be
renderers: [new Geozet.Renderer.Anchor()]
Regards,
Slawomir
Am 10.06.2010 09:32, schrieb Bart van den Eijnden:
> Hi list,
> I am trying to use a custom renderer for a Vector Layer. However, if I interpret the code correctly, there is an issue there right now. Hopefully somebody can clarify if I am doing something wrong.
> I am defining my layer in the following way:
> vectorLayer = new OpenLayers.Layer.Vector("Bekendmakingen", {
> styleMap: new OpenLayers.StyleMap({'default':{
> cssClass: "${category}"
> renderer: new Geozet.Renderer.Anchor(),
> strategies: [new Geozet.Strategy.PrintList()]
> However, the constructor of the renderer normally gets the root div as the first argument, but since the vectorLayer has not yet been rendered, I cannot assign it as yet.
> If I look in the Vector.js code I see in the initialize function:
> OpenLayers.Layer.prototype.initialize.apply(this, arguments);
> // allow user-set renderer, otherwise assign one
> if (!this.renderer || !this.renderer.supported()) {
> this.assignRenderer();
> So after the prototype initialize has been called, this.div is there, and I need to "assign' it to my custom renderer.
> So I would expect:
> Renderer to have a setContainer function, and the constructor of the Vector layer to use that function if a user-set renderer has been used.
> TIA.
> Best regards,
> Bart
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Slawomir Messner
Forschungszentrum "Deutscher Sprachatlas"
06421-28-24981
More information about the Dev
