[OpenLayers-Dev] using custom renderer on Layer.Vector
christopher.schmidt at nokia.com
Thu Jun 10 07:00:54 EDT 2010
On Jun 10, 2010, at 6:15 AM, ext Bart van den Eijnden wrote:
> Yes I know that option exists, but in that case I need to put my custom Renderer in the OpenLayers namespace, which is not what I want.
Heh. Apparently I was just too asleep. To answer this concern: I think
*this* is the bug, and should be fixed :)
-- Chris
> Best regards,
> Bart
> On Jun 10, 2010, at 9:57 AM, Slawomir Messner wrote:
>> Ok, the last mail was maybe a little short. We do it like this:
>> renderers: ["REDESVG", "SVG", "VML"]
>> As you see we use rendereS and an array, so for you it would be
>> renderers: [new Geozet.Renderer.Anchor()]
>> Regards,
>> Slawomir
>> Am 10.06.2010 09:32, schrieb Bart van den Eijnden:
>>> Hi list,
>>> I am trying to use a custom renderer for a Vector Layer. However, if I interpret the code correctly, there is an issue there right now. Hopefully somebody can clarify if I am doing something wrong.
>>> I am defining my layer in the following way:
>>> vectorLayer = new OpenLayers.Layer.Vector("Bekendmakingen", {
>>> styleMap: new OpenLayers.StyleMap({'default':{
>>> cssClass: "${category}"
>>> renderer: new Geozet.Renderer.Anchor(),
>>> strategies: [new Geozet.Strategy.PrintList()]
>>> However, the constructor of the renderer normally gets the root div as the first argument, but since the vectorLayer has not yet been rendered, I cannot assign it as yet.
>>> If I look in the Vector.js code I see in the initialize function:
>>> OpenLayers.Layer.prototype.initialize.apply(this, arguments);
>>> // allow user-set renderer, otherwise assign one
>>> if (!this.renderer || !this.renderer.supported()) {
>>> this.assignRenderer();
>>> So after the prototype initialize has been called, this.div is there, and I need to "assign' it to my custom renderer.
>>> So I would expect:
>>> Renderer to have a setContainer function, and the constructor of the Vector layer to use that function if a user-set renderer has been used.
>>> TIA.
>>> Best regards,
>>> Bart
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Slawomir Messner
>> Forschungszentrum "Deutscher Sprachatlas"
>> 06421-28-24981
>> Dev mailing list
> Dev mailing list
Regards,
Christopher Schmidt
Nokia
More information about the Dev
