[OpenLayers-Dev] constructor signatures
Eric Lemoine
eric.lemoine at camptocamp.com
Fri Jun 18 01:17:03 EDT 2010
On Friday, June 18, 2010, <christopher.schmidt at nokia.com> wrote:
> On Jun 17, 2010, at 6:33 PM, ext Tim Schaub wrote:
>> var popup = new OpenLayers.Popup.FramedCloud({
>> location: xy,
>> text: text,
>> closeBox: true
>> I think the second form is more readable and less prone to errors.
>> The one argument constructor is nothing new. We're doing it already in
>> some places in the library. People coming from popular JavaScript
>> frameworks are comfortable with this.
>> In adding the WMTS layer, I created a constructor that takes a single
>> argument. If others agree that this is the way forward, I think there
>> is sense in getting used to it before 3.0.
>> I am bringing this up here because Chris objected to my commit of the
>> WMTS layer and reopened the ticket.
>> If anybody else has an opinion about the many versus one argument
>> constructor, please weigh in.
> In general, for 2.x, I am supportive of having required
> arguments as seperate parameters, and optional arguments in a single
> object. Some of our existing classes -- popups being a big one :) --
> are obviously not following this convention.
> I do not think it is unreasonable to make some things 'required' even
> if they are actually not technically required. In the WMS spec, the
> Title attribute is required, even though there is no technical reason
> why this matters; it simply makes working with layers easier when
> they have names, rather than just positions in an array.
> When creating a new subclass, One of the first things that I do is
> compare the Constructor signatures of the parent class to the
> subclass. If the parent has a constructor which is not a 'subset' of
> the child object, it usually means I've done something wrong. In the
> case of Layer, the parent class has:
> Layer(name, options)
> My convention for subclasses, then, would be that I could put things
> *between* 'name' and 'options', but that I could not get rid of those
> things; Layer.WMS has:
> Layer(name, params, options);
> In all cases I'm aware of (Though I have not examined filters and rules
> extensively, so this may not be true in some portions of the code),
> all of our subclassed items may add things after the 'required'
> parameters, and before the 'options' parameter (which provides a
> space for non-required parameters).
> I am comfortable with 'name' being treated as a 'required' parameter
> of layers. I am in favor of maintaining the style of 'extending'
> parameters following this pattern in 2.x; specifically, if a
> parent class declares something 'required', the subclass should
> generally treat it as 'required' (and therefore a seperate parameter)
> unless doing so is significantly painful.
> Backing out on something that is one of our few points of consistency --
> Layers require a string as their first argument -- would make me
> sad, but I'm not going to argue that we need to revert a change
> because of it. I just think it's a worthwhile convention to hold onto
> until we really go ahead and change many of our conventions for the
> Glorious Future.
> Going forward into 3.x, I am okay with abandoning this convention
> in favor of making everything optional. I don't like it, personally,
> but if this is common Javascript convention, I'm willing to go with
> it.
> Apologies if I nitpicked on this one specific feature; I can understand
> that the WMTS layer was likely a lot of work, and am sure that it will
> help many people. I just wanted to comment on the convention change
> because I thought it might actively trip people up.
Hi.
I agree with Chris regarding layer args and consistency.
And I fully support using config objects only in 3.x, with required
options documented as such.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
