[OpenLayers-Dev] constructor signatures
christopher.schmidt at nokia.com
Fri Jun 18 07:51:18 EDT 2010
On Jun 18, 2010, at 6:05 AM, ext Zac Spitzer wrote:
> Every one is more than welcome to share their opinions and examples of their experiences and frustrations with Ol.
If you want to do that, take it to a separate thread, please.
Let this one be about discussing the current issue of what
we use for constructor arguments.
-- Chris
> I had the exact same experience myself.
> I'd like to see a debug build which validates argument collections, both for required and unknown arguments. One which can be stripped out when building a single file. Also with some generous debug messages, as with my email the other day with the JSON issue.
> Is it possible to generate full parameter examples via natural docs?
> On 18 Jun 2010 18:49, "Richard Duivenvoorde" <rdmailings at duif.net> wrote:
> > Don't have so much credit to interfere, but
> > as a user I have seen users (mw) who made the mistake with eg the
> > WMS-layer by putting param-arguments into the options-object and vice versa
> > what about always 2 object arguments:
> > - the required
> > - the optional (optional :-) )
> > making it possible to check for the required (off course also possible
> > with one object!)
> > but for users googling for examples and copying code, it makes sense to
> > know that the first object will always be the required ones (so in all
> > googled code snippets the same).
> > Seeing code with 8 parameters (even in one object), not knowing which
> > ones are really required is not that easy.
> > (though you can always read the api docs offcourse...)
> > speaking of api-docs, it would be really nice to have the inherited
> > required args, functions, props into a class definition also
> > Regards,
> > On 06/18/2010 01:22 AM, Schuyler Erle wrote:
> >> On Jun 17, 2010, at 3:33 PM, Tim Schaub wrote:
> >>> In adding the WMTS layer, I created a constructor that takes a single
> >>> argument. If others agree that this is the way forward, I think there
> >>> is sense in getting used to it before 3.0.
> >>> I am bringing this up here because Chris objected to my commit of the
> >>> WMTS layer and reopened the ticket.
> >>> If anybody else has an opinion about the many versus one argument
> >>> constructor, please weigh in.
> >> I think that we can address this by placing a practical guideline on the number of arguments to any function in OL. For example, we could express a style guideline that any method that might take more than 3 arguments should use a dict instead of OR in addition to one or two fixed arguments. We can then require that any violation of this guideline be accompanied by a strong justification in the code comments.
> >> SDE
> >> _______________________________________________
> >> Dev mailing list
> >> Dev at openlayers.org
> >> http://openlayers.org/mailman/listinfo/dev
> > Dev mailing list
> <ATT00001..txt>
Regards,
Christopher Schmidt
Nokia
More information about the Dev
