[OpenLayers-Dev] constructor signatures
christopher.schmidt at nokia.com
Fri Jun 18 11:34:47 EDT 2010
On Jun 18, 2010, at 11:02 AM, ext Tim Schaub wrote:
> To clarify here, specifically for the WMTS layer, these are the strictly
> required properties:
> * url
> * layer identifier
> * style identifier
> * matrixSet identifier
> And who knows, we might get smarter in the future and find that we can
> derive sensible defaults for those*. Anyway, at least four required
> arguments to start with. And by required I mean that the layer will not
> render anything when added to a map if those arguments are not provided.
> I'm putting together a patch for the layer that will make the
> constructor throw an error when the layer is not properly configured -
> to reduce the chance for user error.
A good plan. And stuff like this -- specifically, the potential that
the defaults could *change* in the future -- is the kind of thing that
makes the current 'required are seperate from not required' silly.
(In a WMS layer, 'params' is required -- but in reality, there's no reason
you *have* to have parameters for a given layer -- same kind of problem.)
> Having a single argument for the WMTS layer constructor also makes
> things nicer for creating layers from parsed capabilities. This is a
> detail specific to the WMTS layer, but I had it in mind when making the
> decision. In general, a single configuration argument is more
> convenient to pass around, extend, serialize (assuming people want to
> persist app configuration), etc.
I'm reasonably convinced that this is the right thing for the future.
>> Backing out on something that is one of our few points of consistency --
>> Layers require a string as their first argument -- would make me
>> sad, but I'm not going to argue that we need to revert a change
>> because of it. I just think it's a worthwhile convention to hold onto
>> until we really go ahead and change many of our conventions for the
>> Glorious Future.
>> Going forward into 3.x, I am okay with abandoning this convention
>> in favor of making everything optional. I don't like it, personally,
>> but if this is common Javascript convention, I'm willing to go with
>> it.
> I completely understand this. I suspected this was about a change that
> would make you sad.
> So, right now we have an opportunity. We can create new constructors
> that are forward compatible, or we can create new constructors that
> follow old conventions (and need to be changed in the future).
> I hear that you (Chris), Eric, and Bart favor going with old conventions
> rather than forward compatibility.
That about sums it up. :)
Regards,
Christopher Schmidt
Nokia
More information about the Dev
