[OpenLayers-Dev] unable to change zIndex on vector elements
Vito Tafuni
vito at vitotafuni.com
Sat Jun 19 03:44:55 EDT 2010
thank you very much
My error was to apply the zindexing parameter to the wrong layer.
since you were so kind i have another question about vector graphics:
every vector shape I can select with the graphicname parameter
(OpenLayers.Feature.Vector) is drawn pointing on the map with it's center.
is there a way to apply an offset so i can use for example an angle of the
rectangle shape to point on the map??
thanks
-Vito-
Tafuni Vito
"Verba volant, scripta manent... data corrupted"
2010/6/18 Tim Schaub <tschaub at opengeo.org>
> Vito Tafuni wrote:
> > i've tryed to enable zindexing in the rendererOptions
> > and set different values for the graphicZIndex in the map style
> > but i cannot select a polygon and let it go on top!
> > any solutions??
> While it is hard to see unless there are overlapping features, this
> example changes the graphicZIndex property of a symbolizer when a
> feature is rendered with the "select" intent:
> http://openlayers.org/dev/examples/stylemap.html
> Hope that helps,
> Tim
> > Tafuni Vito
> > vito at vitotafuni.com <mailto:vito at vitotafuni.com>
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100619/6aa6e673/attachment.html
More information about the Dev
