[OpenLayers-Dev] [OpenLayers-Users] WFS GetFeature - again
BERÉNYI Attila
atis at airdesignstudio.hu
Tue Jun 29 12:29:54 EDT 2010
To answer my own question: the response is created in the gmgml
namespace so OpenLayers cannot interpret it. It can be solved by turning
on the Feature Collection Namespace in WFS option in Geomedia before
publishing the WFS service.
Probably it can be solved by implementing gmgml namespace in OpenLayers
as well, does it worth a new feature ticket?
BR,
Attila
2010.06.22. 20:36 keltezéssel, BERÉNYI Attila írta:
> Hi,
> I've facing a problem regarding the GetFeature function again, and I'm
> not quite sure whether it is an OpenLayers bug or the server
> application fails.
> So, I've a WMS and a WFS service served by Geomedia WebMap:
> http://webmap.viamap.hu/ol/getFeatureTest.html
> The GetFeature gets a correct response from the WFS service, e.g.:
> |<?xml version="1.0" encoding="UTF-8"?>
> ||<gmgml:FeatureCollection xmlns="http://www.intergraph.com/geomedia/gml" xmlns:gml="http://www.opengis||.net/gml" xmlns:gmgml="http://www.intergraph.com/geomedia/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"|| xsi:schemaLocation='http://www.intergraph.com/geomedia/gml http://webmap.viamap.hu/testWFS/request.aspx||?request=DescribeFeatureType&VERSION=1.1.0&SERVICE=WFS&OUTPUTFORMAT=text/xml;subtype=gml||/3.1.1'><gml:boundedBy><gml:Envelope srsName="EPSG:23700"><gml:lowerCorner>660000 236000</gml:lowerCorner||><gml:upperCorner>666000 240000</gml:upperCorner></gml:Envelope></gml:boundedBy><gml:featureMember><gmgml||:szelvenyhalo gml:id="szelvenyhalo.2676"><gmgml:szelvenyszam>65-421</gmgml:szelvenyszam><gmgml:felmeres||>1997</gmgml:felmeres><gmgml:ID>2676</gmgml:ID><gmgml:Geometry><gml:Polygon srsName="EPSG:23700"><gml||:exterior><gml:LinearRing><gml:posList srsDimension="2">660000 236000 660000 240000 666000 240000 666000|| 238000 666000 236000 660000 236000</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></gmgml||:Geometry></gmgml:szelvenyhalo></gml:featureMember></gmgml:FeatureCollection>|
> although the result cannot be processed, because of the following error:
> obj.attributes is undefined
> http://webmap.viamap.hu/ol/lib/OpenLayers-2.9.1/lib/OpenLayers/Format/GML/Base.js
> Line 397
> Is it an OpenLayers bug?
> BR,
> Attila
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100629/ab3b01a3/attachment.html
More information about the Dev
