[OpenLayers-Dev] Map event confusion
Marc Jansen
jansen at terrestris.de
Fri Mar 26 14:32:46 EDT 2010
Hi Tim,
comments inline.
Tim Schaub schrieb:
> I'm in favor of removing this cruft as well.
> To be clear, here are things that "work" currently:
> // myapp.js
> map.events.on({
> popupopen: myPopupOpenListener,
> // and the rest
> var openPopup = function() {
> var pop = createPopup(); // defined elsewhere
> pop.show();
> map.events.triggerEvent("popupopen", {popup: pop});
> Currently, if application code makes use of the events listed below, the
> corresponding event listeners get called appropriately.
> After removing these entries from the EVENT_TYPES array, these listeners
> will not get called.
I proposed to remove them from the docs, not the EVENT_TYPES array. Any
application having code like yours will continue to work. As for the
release *after* 2.10, I'd suggest changing the array as well.
BTW: I opened the ticket (it's #2553), see
http://trac.openlayers.org/ticket/2553
Regards,
Marc
> Again, I'm fine with this. Just wanted to be clear that we are changing
> the behavior of any applications that might be using these named events
> (perhaps none).
> Tim
More information about the Dev
