[OpenLayers-Dev] 3 failing tests in Safari
Andreas Hocevar
ahocevar at opengeo.org
Tue Mar 30 15:43:27 EDT 2010
On 2010-03-30 21:18 , Bart van den Eijnden wrote:
> Hi list,
> we have 3 failing tests in Safari, does anyone know if these are known
> issues or if they are fixable (before I even attempt)? TIA.
> Control/PanZoom.html:
> test_Control_PanZoom_control_events planned 35 assertions but got 1;
> fail 1 ok 0
> fail unable to open window for Control/PanZoom.html
This one is just because popup windows are blocked on your Safari.
For the others, I don't know.
-Andreas.
> Format/ArcXML.html:
> test_Format_ArcXML_parseerror fail 1 ok 0
> fail parsing failed to fail
> Format/ArcXML/Features.html:
> test_parseerror fail 1 ok 0
> fail reading didn't fail
> Best regards,
> Bart
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
