[OpenLayers-Dev] Can OpenLayers call a java program
Zac Spitzer
zac.spitzer at gmail.com
Thu May 6 22:45:56 EDT 2010
write some server side code in asp, jsp, coldfusion, php, whatever
which calls java, or do you want to use an applet?
it's the same as any other web application
On 7 May 2010 12:34, Anindya <anindya1972 at gmail.com> wrote:
> Hi,
> Can OpenLayers call a java program? If yes, can anybody provide any example
> which explains how OpenLayers call a java program
> Regards,
> Anindya
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-OpenLayers-call-a-java-program-tp5017563p5017563.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the Dev
